P1839
Manufacturer Specific Definitions for P1839
Buick | Internal Mode Switch 'C' Circuit Low Voltage |
Cadillac | Internal Mode Switch 'C' Circuit Low Voltage |
Chevrolet | Internal Mode Switch 'C' Circuit Low Voltage |
Citroen | Transmission Transfer Case Shift Motor Open Circuit |
Daewoo | Eds 3 Drv Crct Gnd Short |
Ford | Transmission Transfer Case Shift Motor Open Circuit |
Gm | Internal Mode Switch 'C' Circuit Low Voltage |
Kenworth | P1839 - Upstream NOx sensor AT1IGC1 high rate fault |
Lincoln | Transmission Transfer Case Shift Motor Open Circuit |
Mercury | Transmission Transfer Case Shift Motor Open Circuit |
Peterbilt | P1839 - Upstream NOx sensor AT1IGC1 high rate fault |
Peugeot | Transmission Transfer Case Shift Motor Open Circuit |
