P1838
Reading P1838 on your car
P1838 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1838
BuickInternal Mode Switch 'A' Circuit High Voltage
CadillacInternal Mode Switch 'A' Circuit High Voltage
ChevroletInternal Mode Switch 'A' Circuit High Voltage
CitroenTransmission Transfer Case Shift Motor Circuit Failure
FordTransmission Transfer Case Shift Motor Circuit Failure
GmInternal Mode Switch 'A' Circuit High Voltage
LincolnTransmission Transfer Case Shift Motor Circuit Failure
MercuryTransmission Transfer Case Shift Motor Circuit Failure
PeugeotTransmission Transfer Case Shift Motor Circuit Failure
We have not gotten around to publishing a technical guide specifically for P1838 yet.
