P1836
Reading P1836 on your car
P1836 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1836
| Make | Fault Location |
| Buick | Kick-Down Switch Failed Open |
| Cadillac | Kick-Down Switch Failed Open |
| Chevrolet | Kick-Down Switch Failed Open |
| Citroen | Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure |
| Gm | Kick-Down Switch Failed Open |
| Hyundai | Bleed Pressure Line Test Error |
| Mitsubishi | Shift Fork 1 Malfunction |
| Peugeot | Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure |
| Pontiac | Kick-Down Switch Failed Open |
| Saturn | Kick-Down Switch Failed Open |
We have not gotten around to publishing a technical guide specifically for P1836 yet.
