P1832
Reading P1832 on your car
P1832 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1832
CitroenTransmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
FordTransmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
HyundaiClutch Thermal Overstress Shutdown
LincolnTransmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
Mercedes-BenzTransmission shift lever control module – short circuit
MercuryTransmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
MitsubishiShift Fork Position Sensor 3 System Voltage High Range Out
PeugeotTransmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
We have not gotten around to publishing a technical guide specifically for P1832 yet.
