P1826
Manufacturer Specific Definitions for P1826
Buick | Transmission range (TR) switch, signal ‘C’ voltage high |
Cadillac | Internal Mode Switch Circuit 'C' High |
Chevrolet | Transmission range (TR) switch, signal ‘C’ voltage high |
Citroen | Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery |
Ford | Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery |
Gm | Transmission range (TR) switch, signals ‘C’ – voltage high |
Hyundai | Pressure Sensor for 4WD Supply Short to Ground |
Mitsubishi | Shift Fork Position Sensor 2 System Voltage High Range Out |
Peugeot | Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery |
Pontiac | Transmission range (TR) switch, signal ‘C’ -voltage high |
Saturn | Transmission range (TR) switch, signal ‘C’voltage high |
