P1823
Manufacturer Specific Definitions for P1823
Buick | Transmission range (TR) switch, signal ‘P’ voltage low |
Cadillac | Internal Mode Switch Circuit 'P' Low |
Chevrolet | Transmission range (TR) switch, signal ‘P’ voltagelow |
Citroen | Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground |
Gm | Internal Mode Switch Circuit 'P' Low (4T80-E Transmission) |
Hyundai | Pump for 4WD Motor Wire Short to GND |
Mitsubishi | Shift Fork Position Sensor 1 System Neutral |
Peugeot | Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground |
Pontiac | Transmission range (TR) switch, signal ‘P’ -voltage low |
Porsche | Pressure regulator 3 |
Saturn | Transmission range (TR) switch, Signal ‘P’voltage low |
