P1822
Manufacturer Specific Definitions for P1822
Buick | Transmission range (TR) switch, signal ‘B’ voltage high |
Cadillac | Internal Mode Switch Circuit 'B' Low |
Chevrolet | Transmission range (TR) switch, signal ‘B’ voltage high |
Citroen | Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery |
Ford | Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery |
Gm | Internal Mode Switch Circuit 'B' Low (4T80-E Transmission) |
Hyundai | Pump for 4WD Motor Wire Open Load |
Mitsubishi | Shift Fork Position Sensor 1 System Output Range Out |
Peugeot | Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery |
Pontiac | Transmission range (TR) switch, signal ‘B’ voltage high |
Saturn | Transmission range (TR) switch, signal ‘B’voltage high |
We have not gotten around to publishing a technical guide specifically for P1822 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
