P1820
Manufacturer Specific Definitions for P1820
Buick | Transmission range (TR) switch, signal ‘A’ voltage low |
Cadillac | Internal Mode Switch Circuit 'A' Low |
Chevrolet | Transmission range (TR) switch, signal ‘A’ voltage low |
Citroen | Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure |
Ford | Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure |
Gm | Internal Mode Switch Circuit 'A' Low (4T80-E Transmission) |
Hyundai | Pump for 4WD Motor High Overcurrent Detected |
Infiniti | Engine Speed Signal |
Mitsubishi | Shift Fork Position Sensor 1 System Voltage Low Range Out |
Nissan | Engine Speed Signal |
Peugeot | Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure |
Pontiac | Transmission range (TR) switch, signal ‘A’ -voltage low |
Saturn | Transmission range (TR) switch, signal ‘A’voltage low |
We have not gotten around to publishing a technical guide specifically for P1820 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
