P1818
Manufacturer Specific Definitions for P1818
Buick | Transmission Fluid Pressure Valve Position Switch-Drive Without Drive Ratio |
Cadillac | Transmission Fluid Pressure Valve Position Switch-Drive Without Drive Ratio |
Chevrolet | Transmission fluid pressure (TFP) switch -invalidgear selection |
Citroen | Transmission Neutral Safety Switch Short Circuit To Battery |
Gm | Transmission Fluid Pressure Valve Position Switch-Drive Without Drive Ratio |
Infiniti | Actuator Position Switch |
Isuzu | Transmission fluid pressure (TFP) switch – invalid gear selection |
Lexus | Shift control solenoid – circuit malfunction |
Nissan | Actuator Position Switch |
Peugeot | Transmission Neutral Safety Switch Short Circuit To Battery |
Pontiac | Transmission fluid pressure (TFP) switch -invalidgear selection |
Porsche | Pressure regulator 2 |
Saturn | Transmission fluid pressure (TFP) switch -invalidgear selection |
Toyota | Shift control solenoid - circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1818 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
