P1815 – Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
Reading P1815 on your car
P1815 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1815
We have not gotten around to publishing a technical guide specifically for P1815 – Transmission 4-Wheel Drive Mode Select Short Circuit To Ground yet.
I have a 2005 cadi srx reading out P1815 p0700 my key is locked in the ignition and battery has died
