P1810
Manufacturer Specific Definitions for P1810
Buick | Transmission Fluid Pressure Valve Position Switch Circuit |
Cadillac | Transmission Fluid Pressure Valve Position Switch Circuit |
Chevrolet | Transmission fluid pressure (TFP) switch manual valve position |
Citroen | TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery |
Ford | Transmission Fluid Pressure Valve Position Switch Circuit |
Gmc | Transmission gear pressure switch, signal -circuit malfunction |
Gm | Transmission Pressure Switch Manifold Fault Conditions |
Hummer | Transmission fluid pressure (TFP) switch -manual valve position |
Infiniti | 4 LO Switch |
Isuzu | AT – manual valve position pressure switch malfunction |
Lexus | CAN Data Bus Malfunction |
Nissan | 4 LO Switch |
Oldsmobile | Transmission fluid pressure (TFP) switch -manual vaive position |
Peugeot | TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery |
Pontiac | Transmission fluid pressure (TFP) switch -manual valve position |
Saab | Transmission fluid pressure (TFP) switch – manual valve position |
Saturn | Transmission fluid pressure (TFP) switch manual valve position |
Toyota | CAN data bus malfunction - malfunction |
