P1786
Reading P1786 on your car
P1786 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1786
| Make | Fault Location |
| Acura | AT - poor gear shift |
| Citroen | 3-2 Downshift Error |
| Daewoo | Engine Rpm Output Circuit |
| Ford | Transmission System Second or Third Gear Fault |
| Honda | AT – poor gear shift – V6 |
| Hyundai | Inhibitor Switch Circuit High |
| Isuzu | AT - poor gear shift |
| Lincoln | Gear selection, 3-2 -downshift malfunction |
| Peugeot | 3-2 Downshift Error |
We have not gotten around to publishing a technical guide specifically for P1786 yet.
