P1781
Manufacturer Specific Definitions for P1781
Buick | Engine Torque Signal Circuit |
Cadillac | Engine Torque Signal Circuit |
Chevrolet | Engine control module (ECM), torque reduction signal -out of range |
Chrysler | Over Drive Pressure Switch Sense Circuit |
Citroen | 4X4 Switch Out of Self Test Range |
Daewoo | Actuator Mal |
Dodge | Over Drive Pressure Switch Sense Circuit |
Ford | 4x4 Low Switch Out of Self-Test Range Conditions |
Gmc | Transmission control module (TCM), MIL requestsignal -voltage high/low |
Gm | Transmission control module (TCM), MIL request signal -voltage high/low |
Hyundai | Battery Voltage Low |
Jeep | Over Drive Pressure Switch Sense Circuit |
Land Rover | Transmission mode selection switch 4×4 – circuit out of self-test range |
Lexus | Shift Lever Switch Malfunction |
Lincoln | 4x4L switch -out of self-test range |
Mazda | 4×4 low range switch – out of self-test range |
Mercury | 4x4L switch -out of self-test range |
Opel | CAN data bus,ECM actual torque signal - malfunction detected |
Peugeot | 4X4 Switch Out of Self Test Range |
Toyota | Shift lever switch - malfunction |
We have not gotten around to publishing a technical guide specifically for P1781 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
