P1776
Manufacturer Specific Definitions for P1776
Chrysler | Solenoid switch valve locked in UR (low/reverse) position |
Citroen | Ignition Retard Request Duration Fault |
Daewoo | Power Control Unit Mal |
Dodge | Solenoid switch valve locked in UR (low/reverse) position |
Hyundai | Power Control Module-Malfunction. |
Infiniti | Ignition Retard Request Duration Fault |
Jaguar | Engine control module (ECM) - TCM retard signal |
Jeep | Solenoid switch valve locked in UR (low/reverse) position -wiring open/short circuit |
Land Rover | Transmission control system -torque interface malfunction |
Mazda | AT – torque reduction signal 2 – signal problem |
Nissan | Torque converter clutch solenoid – converter slip during lock condition |
Peugeot | Ignition Retard Request Duration Fault |
Ram | Solenoid switch valve locked in UR (low/reverse) position |
