P1774
Reading P1774 on your car
P1774 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1774
| Make | Fault Location |
| Daewoo | Crc Sensor Mal |
| Hyundai | Speed Command PWM Line |
| Infiniti | AT – low coast brake solenoid valve – malfunction |
| Nissan | Automatic transmission low coast brake – solenoid valve malfunction |
We have not gotten around to publishing a technical guide specifically for P1774 yet.
