P1768
Reading P1768 on your car
P1768 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1768
AcuraAT - lock-up clutch not engaging
CitroenPerformance / Normal / Winter Mode Input Malfunction
FordPerformance / Normal / Winter Mode Input Malfunction
HondaAT – lock-up clutch not engaging
IsuzuAT - lock-up clutch not engaging
Land RoverEconomy/sport mode switch, winter weather
MitsubishiTransaxle Control Relays Always Off
PeugeotPerformance / Normal / Winter Mode Input Malfunction
We have not gotten around to publishing a technical guide specifically for P1768 yet.
