P1767
Reading P1767 on your car
P1767 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1767
CitroenTorque Converter Clutch Circuit Malfunction
FordTorque Converter Clutch Solenoid Circuit Malfunction
HyundaiCAN ABS Loss of Signal
InfinitiAT- high/low reverse solenoid valve – malfunction
Land RoverTorque converter clutch (TCC)
LincolnTorque converter clutch (TCC) -circuit malfunction
MazdaAT – torque converter clutch (TCC) solenoid- circuit malfunction
NissanAutomatic transmission high/low reverse – solenoid valve malfunction
PeugeotTorque Converter Clutch Circuit Malfunction
We have not gotten around to publishing a technical guide specifically for P1767 yet.
