P1764
Reading P1764 on your car
P1764 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1764
ChryslerGovernor Pressure Sensor Too Low Conditions
DaewooTcu Can Comm. Control Mal
DodgeGovernor pressure sensor -signal low
HyundaiCAN Controller-Malfunction.
InfinitiAT- direct clutch – solenoid valve malfunction
JeepGovernor pressure sensor -signal low
NissanAutomatic transmission direct clutch – solenoid valve malfunction
PorscheInstrument cluster triggering
RamGovemor pressure sensor -signal low
We have not gotten around to publishing a technical guide specifically for P1764 yet.
