P1762
Manufacturer Specific Definitions for P1762
Chrysler | Governor Press. Sensor Too Low or High Conditions |
Citroen | Overdrive Band Failed Off |
Daewoo | Ecu Ram Mal |
Dodge | Govemor pressure sensor -incorrect signal |
Ford | Overdrive Band Failed Off |
Hyundai | Control Module-RAM |
Infiniti | AT- direct clutch- solenoid valve malfunction |
Jeep | Govemor pressure sensor -incorrect signal |
Lincoln | Overdrive band failed/off |
Mazda | Transmission – band failure |
Nissan | Automatic transmission direct clutch – solenoid valve malfunction |
Peugeot | Overdrive Band Failed Off |
Porsche | Shiftlock P/N |
Ram | Governor pressure sensor -incorrect signal |
We have not gotten around to publishing a technical guide specifically for P1762 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
