P1760
Manufacturer Specific Definitions for P1760
Buick | Transaxle Control Module Supply Voltage Interrupted |
Cadillac | Transaxle Control Module Supply Voltage Interrupted |
Chevrolet | Transaxle Control Module Supply Voltage Interrupted |
Citroen | Pressure Control Solenoid -A- Short Circuit |
Daewoo | Ecu Program Mal |
Ford | Transmission System Fault Conditions |
Gm | TCM Supply Voltage Interrupted (4L30-E Transmission) |
Hyundai | Control Module-Programming |
Infiniti | AT- overrun clutch solenoid – voltage low |
Jaguar | Transmission System Fault Conditions |
Land Rover | Transmission fluid pressure (TFP) solenoid – short circuit |
Lexus | AT – pressure control shift solenoid |
Lincoln | Transmission fluid pressure (TFP) solenoid -short circuit |
Mazda | AT – electronic pressure control solenoid – short to ground |
Mercury | Overdrive clutch solenoid valve -circuit malfunction |
Nissan | AT – overrun clutch solenoid – voltage low |
Opel | System voltage,ignition - out of limits |
Peugeot | Pressure Control Solenoid -A- Short Circuit |
Pontiac | Transmission fluid pressure (TFP) solenoid -circuit malfunction |
Toyota | AT - pressure control shift solenoid |
We have not gotten around to publishing a technical guide specifically for P1760 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
