P1756
Reading P1756 on your car
P1756 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1756
ChryslerGovernor Press, over 3 PSI in gear (0 MPH) Conditions
CitroenShift Solenoid B Performance
Daewoo3 Shift Pos. Indic. Lamp
DodgeGovemor pressure not equal to target (15-20 PSI) -mid pressure malfunction
FordShift Solenoid 2 Performance Conditions
HyundaiLamp ‘3’
JeepGovernor pressure not equal to target (15-20 PSI)-mid pressure malfunction
Land RoverShift solenoid (SS) 2 -defective
LincolnShift solenoid (SS) 8 -performance
MazdaAT – shift solenoid 2- open circuit
PeugeotShift Solenoid B Performance
RamGovernor pressure not equal to target (35-40 PSI)
We have not gotten around to publishing a technical guide specifically for P1756 yet.
