P1751
Reading P1751 on your car
P1751 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1751
AcuraAT - hydraulic system mechanical malfunction
AudiTransmission control module (TCM) – supply voltage high
ChryslerTransmission system relay -circuit malfunction
CitroenShift Solenoid A Performance
DaewooAuto Control Relay -Mal.
DodgeTransmission system relay -circuit malfunction
FordShift Solenoid 1 Performance Conditions
HondaAT – hydraulic system mechanical malfunction
HyundaiAuto Control Relay-Malfunction
KenworthP1751 - Mil lamp driver short circuit to battery fault
Land RoverShift solenoid (SS) 1 – defective
LincolnShift solenoid (SS) A -performance
MahindraCoolant Temp Display To Cluster Wire Open
MazdaAT – shift solenoid 1 – open circuit
MitsubishiAutomatic transmission – control relay malfunction
PeterbiltP1751 - Mil lamp driver short circuit to battery fault
PeugeotShift Solenoid A Performance
We have not gotten around to publishing a technical guide specifically for P1751 yet.
