P1750
Manufacturer Specific Definitions for P1750
Acura | AT - hydraulic system mechanical malfunction |
Audi | Transmission control module (TCM) – supply voltage low |
Daewoo | Tps Comm Mal |
Dodge | Torque converter clutch (TCC) solenoid/ transmission shift control valve/transmission pressure control solenoid -circuit malfunction |
Eagle | Torque converter clutch (TCC) solenoid/ transmission shift control valve/transmission pressure control soienoid -circuit malfunction |
Honda | AT – hydraulic system mechanical malfunction |
Hyundai | TPS Communication Unification Malfunction. |
Land Rover | Transmission fluid pressure (TFP) – maximum control limit reached |
Mahindra | Error In The Plausibility Of Current Energizing Time With Maximum Permitted Energizing Time |
Mercedes-Benz | Transmission shift lever control module – supply voltage low . |
Mitsubishi | AT- torque converter/shift control and pressure control solenoid valves – malfunction |
Pontiac | Torque converter clutch (Tee)solenoid/transmission shift control valve/transmission pressure control solenoid -circuit malfunction |
Porsche | Voltage Supply Solenoid Valve Pressure Regulators 1 |
