P1747
Manufacturer Specific Definitions for P1747
Audi | Solenoid valves, supply voltage – open circuit/short to ground |
Citroen | Pressure Control Solenoid -A- Short Circuit |
Daewoo | Tcu - Ecu Comm Line #1 Mal |
Ford | Electronic Pressure Control Solenoid 'A' Short Circuit |
Hyundai | TCM-ECM Communication Line #1 Malfunction. |
Land Rover | Transmission fluid pressure (TFP) solenoid – solenoid closed |
Lincoln | Transmission fluid pressure (TFP) solenoid -circuit malfunction |
Mazda | AT – electronic pressure control solenoid – high input |
Mercedes-Benz | CAN data bus, TCM/instrument panel – malfunction |
Peugeot | Pressure Control Solenoid -A- Short Circuit |
Hello
Have an 03 f150 v6, just did the same thing. Except even in park, once you rev the engine, it stutters and misses. Idles great! Lost 3rd and 4th gear coming home this morning, and checked the codes, I now show 14 codes. Everything from cam sensor to tcc problems. Just all at once. Did replace the exhaust gas pressure return sensor, it had one side blown out, fixed nothing, code still returns for it too.
Lo pudiste arreglar???
Ended up being the main wiring harness on passenger side. Was not in it’s clip and fell on the exhaust manifold, burnt a lot of wires. Replaced harness. Fine now.
Failsafe code po600 p1747 no speedometer 4.4 x5 please help thanks
