P1743
Reading P1743 on your car
P1743 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1743
AcuraAT – gear shift malfunction
BuickThrottle Position Invalid Signal
CadillacThrottle Position Invalid Signal
ChevroletThrottle Position Invalid Signal
CitroenTorque Converter Clutch Solenoid Failied On
DaewooShift Motor (Pos4) - Gnd Short
FordTorque Converter Clutch Solenoid Failed On Conditions
GmThrottle Position Invalid Signal (4L30-E Transmission)
HyundaiPosition 4-Short to Ground
LamborghiniTorque converter clutch solenoid circuit fault
LincolnTorque converter clutch (TCC) solenoid
MahindraError Is The Plausibility Between Engine Speed In Level And Level 2
MazdaTorque converter clutch (TCC) solenoid valve – malfunction
MercuryTorque Converter Clutch Solenoid Failed On Conditions
OpelTorque converter clutch - vibration
PeugeotTorque Converter Clutch Solenoid Failied On
SaabTorque Converter Clutch Solenoid Failed On Conditions
We have not gotten around to publishing a technical guide specifically for P1743 yet.
