P1740
Manufacturer Specific Definitions for P1740
Acura | AT - 4th clutch pressure switch |
Audi | Clutch Temperature Monitoring |
Buick | Torque Control Circuit Conditions |
Cadillac | Transmission control module (TCM) -torque control circuit |
Chevrolet | Cruise control system, overdrive disable signal -voltage low |
Citroen | Torque Converter Clutch Inductive Signature Malfunction |
Daewoo | Shift Motor (Pos1) -Gnd Short |
Dodge | Torque Converter Clutch or Overdrive Solenoid Performance Condition |
Ford | Transmission System Conditions |
Gm | Torque Control Circuit (4L30-E Transmission) Conditions |
Honda | AT – 4th clutch pressure switch |
Hyundai | Position 1-Short to Ground |
Infiniti | CVT lock-up select solenoid valve – malfunction |
Jeep | Torque converter clutch (Tee)/overdrive solenoid -performance problem |
Land Rover | Torque converter clutch (TCC) |
Lincoln | Torque converter clutch (TCC) solenoid -circuit malfunction |
Mazda | Torque converter clutch (TCC) control – malfunction |
Mercedes-Benz | Engine control module (ECM), load signal – plausibility |
Nissan | CVT lock-up select solenoid valve – malfunction |
Opel | AT torque control,signal - malfunction |
Peugeot | Torque Converter Clutch Inductive Signature Malfunction |
Ram | Torque converter clutch (TCC)/overdrive solenoid-performance problem |
Suzuki | Cruise control signal – circuit malfunction |
Volvo | Evaporative emission (EVAP) leak detection pump – no signal |
Volkswagen | Clutch Temperature Monitoring |
