P1723 – Gear 3 incorrect Ratio
Reading P1723 on your car
P1723 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1723
| Make | Fault Location |
| Citroen | Gear 3 incorrect Ratio |
| Daewoo | Control Relay - Stuck |
| Ford | Gear 3 Incorrect Ratio |
| Hyundai | Control Relay - Stuck On |
| Kenworth | P1723 - EMPCD P3 ControlDeviation diagnosis fault - positive |
| Mazda | Shift solenoid (SS) 3- malfunction |
| Peterbilt | P1723 - EMPCD P3 ControlDeviation diagnosis fault - positive |
| Peugeot | Gear 3 incorrect Ratio |
| Volvo | Module cooling fan – no signal |
We have not gotten around to publishing a technical guide specifically for P1723 – Gear 3 incorrect Ratio yet.
How can the Code P1723 for a Kia Sedona 2002, can be fixed and it’s location???
