P1719
Manufacturer Specific Definitions for P1719
Chevrolet | Transmission control module (TCM) -detects excessive variation between transmission input/output shaft speed sensors |
Daewoo | Steering Snsr - High Input |
Dodge | Transmission System Conditions |
Ford | Steering Sensor High Input |
Hyundai | Steering Wheel Angle Sensor N-Input Signal |
Jeep | Skip shift solenoid -wiring open/short circuit |
Kenworth | P1719 - NOXCD NOx Control Deviation Diagnosis - negative |
Lincoln | Overdrive speed sensor -circuit malfunction |
Mahindra | Error In Time Monitoring Of The Shut-Off Path Test |
Mazda | Overdrive system – loss of signal |
Peterbilt | P1719 - NOXCD NOx Control Deviation Diagnosis - negative |
Pontiac | Transmission control module (TCM) -detects excessive variation between transmission input/output shaft speed sensors |
Ram | Skip shift solenoid -circuit malfunction |
