P1715
Manufacturer Specific Definitions for P1715
Citroen | SSB Inductive Signature Malfunction |
Daewoo | A/C Switch |
Dodge | Transmission speed sensor AlB -circuitmalfunction |
Eagle | Transmission speed sensor AlB -circuit malfunction |
Ford | Shift Solenoid 'B' Fault |
Hyundai | Air Conditioning(A/C)Switch |
Infiniti | Automatic transmission turbine shaft speed (TSS) sensor- circuit malfunction |
Jeep | Restricted port in T3 range |
Land Rover | Shift solenoid (SS) 2 – defective |
Lexus | Rear Wheel Speed Sensor Malfunction |
Lincoln | 8hift solenoid (88) B -inductive malfunction |
Mahindra | Shut-Off Path Test Of The Under Voltage Detection |
Mazda | AT – shift solenoid 2 – mechanical failure |
Mercury | Shift Solenoid 'B' Fault |
Mitsubishi | Automatic transmission speed sensors A and 8 – malfunction |
Nissan | Transmission input shaft speed (ISS) sensor – circuit malfunction |
Peugeot | SSB Inductive Signature Malfunction |
Porsche | Speed Signal Left Front |
Ram | Restricted port in T3 range |
Suzuki | Park/neutral position (PNP) switch – circuit malfunction |
Toyota | Rear wheel speed sensor(s) - malfunction |
