P1709
Manufacturer Specific Definitions for P1709
Acura | AT - range position switch |
Citroen | PNP Switch Out Of Self Test Range |
Daewoo | Kick Down Switch |
Ford | Park or Neutral Position Switch Out of Self-Test Range |
Honda | AT - Sport shift mode malfunction |
Hyundai | K/D Servo Switch-Open/Short |
Kenworth | P1709 - O2SPD Lambda Sensor Overrun diagnostic |
Lincoln | Park/neutral pOSition (PNP) switch/clutch pedal position (CPP) switch -out of self-test range |
Mahindra | Error Report Due To An Interrupted Spi Communication |
Mazda | Park/neutral position switch (except B series Pickup)- out of self-test range |
Mercury | Park/neutral position (PNP) switch/clutch pedal position (CPP) switch -out of self-test range |
Peterbilt | P1709 - O2SPD Lambda Sensor Overrun diagnostic |
Peugeot | PNP Switch Out Of Self Test Range |
Suzuki | AT- engine coolant temperature (ECT) sensor/barometric pressure (BARO) sensor- signal malfunction |
Volvo | Park/neutral position (PNP) switch – range/performance problem |
