P1705
Manufacturer Specific Definitions for P1705
AcuraAT - gear shift malfunction
BuickPark Neutral Output Circuit Conditions
CadillacPark Neutral Output Circuit Conditions
ChevroletPark Neutral Output Circuit Conditions
CitroenNot in P or N During KOEO / KOER
DaihatsuShift UP/DOWN SW circuit short
FordManual Lever Position Sensor Out of Self-Test Range
GmPark Neutral Output Circuit (4L30-E Transmission) Conditions
HondaCVT – gear shift malfunction
InfinitiAT- throttle position (TP) sensor- voltage high or low
IsuzuAT - gear shift malfunction
KenworthP1705 - O2SRD Lambda Sensor Model Dynamic Response Diagnostic low fault
Land RoverHigh vehicle speed observed in park
LexusAT – direct clutch speed sensor
LincolnTransmission range (TR) sensor -out of self-test range
MahindraError Check Of No-Load Test Pulse Operation
MazdaTransmission range (TR) sensor- out of self-test range
MercuryThrottle position (TP) switch/sensor
NissanAT – throttle position (TP) sensor- voltage high or low
OpelPark / neutral position (PNP) switch - incorrect signal
PeterbiltP1705 - O2SRD Lambda Sensor Model Dynamic Response Diagnostic low fault
PeugeotNot in P or N During KOEO / KOER
SaabShift solenoid (SS) 2-4 brake pressure control – circuit malfunction
SubaruShift solenoid (SS) 2-4 brake pressure control – circuit malfunction
SuzukiAT- engine coolant temperature (ECT)   sensor – signal malfunction
ToyotaAT - direct clutch speed sensor
We have not gotten around to publishing a technical guide specifically for P1705 yet.
To escalate the priority of this guide in our production queue, please let us know the specifics of your vehicle (make, model, year, miles, and engine) and make a $9.99 donation via the payment button below. We will follow up immediately with additional questions as needed and email you a detailed guide for your vehicle.
Please help support us and let us help you.
