P1703
Manufacturer Specific Definitions for P1703
Citroen | Brake Switch Out Of Self Test Range |
Daewoo | Tps -Open/Ground |
Daihatsu | Lock up speed disaccord |
Ford | Brake On/Off Switch Out of Self-Test Range |
Hyundai | Throttle Position Sensor(TPS)-Open/Short(GND) |
Infiniti | Transmission Control Module ROM |
Land Rover | Transfer box link - signal line |
Lincoln | Brake pedal position (BPP) switch -out of self-test range |
Mahindra | Eep Read Error Based On The Error For More Blocks |
Mazda | Brake pedal position (BPP) switch – torque converter – out of self-test range |
Mercury | Brake pedal position (BPP) switch -out of self-test range |
Nissan | Transmission Control Module ROM |
Peugeot | Brake Switch Out Of Self Test Range |
Saab | Shift solenoid (SS) low clutch timing – circuit malfunction |
Subaru | Shift solenoid (SS) low clutch timing – circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1703 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
