P1702
Manufacturer Specific Definitions for P1702
Citroen | TRS Circuit Intermittent Malfunction |
Daewoo | Tps Circuit - Range /Pf Mal |
Ford | Transmission range (TR) sensor -circuit intermittent |
Hyundai | Throttle Position Sensor(TPS)-Abnormal |
Infiniti | Transmission Control Module RAM |
Land Rover | Transfer box signal line – communication error |
Lincoln | Transmission range (TR) sensor -circuitintermittent |
Mahindra | Eep Erase Error Based On The Error For More Blocks |
Mazda | Transmission range (TR) sensor- circuit malfunction |
Nissan | Transmission Control Module RAM |
Peugeot | TRS Circuit Intermittent Malfunction |
Saab | AT diagnosis signal- voltage low |
Subaru | AT diagnosis signal – voltage low |
Suzuki | Transmission control module (TCM) – memory check sum error |
We have not gotten around to publishing a technical guide specifically for P1702 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
