P1698
Manufacturer Specific Definitions for P1698
Audi | Check DTC Memory Of Steering Column ECU |
Chrysler | CAN data bus, TCM -no signal |
Daewoo | C/F Relay(High Speed) |
Dodge | CAN data bus, transmission control module(TCM) no signal |
Eagle | CAN data bus, transmission control module (TCM) -no signal |
Hyundai | Cooling Fan Relay Circuit-High |
Jeep | CAN data bus, TCM -no signal |
Kenworth | P1698 - Voltage reference 4 minimum range fault |
Peterbilt | P1698 - Voltage reference 4 minimum range fault |
Plymouth | CAN data bus, transmission control module (TCM) -no signal |
Ram | CAN data bus, engine control module (ECM) 2no signal |
Ram | CAN data bus, transmission control module (TCM) no signal |
Saab | Engine torque control cut signal – voltage low |
Subaru | Engine torque control cut signal – voltage low |
Volkswagen | Check DTC Memory Of Steering Column ECU |
We have not gotten around to publishing a technical guide specifically for P1698 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
