P1695
P1695 | Remote Keyless Entry Circuit Low Input Conditions (BUICK, CADILLAC, CHEVROLET, GMC) PCM Fault No CCD Messages From BCM Conditions (CHRYSLER, DODGE) Immobilizer EEPROM Error (HYUNDAI) |
Other Manufacturer Specific Definitions for P1695
Remote Keyless Entry Circuit Low Input Conditions (GM)Remote Keyless Entry Circuit Low Input Conditions (Buick)
Remote Keyless Entry Circuit Low Input Conditions (Cadillac)
CAN data bus, body control module (BCM) no signal (Chrysler)
CAN data bus, body control module (SCM) no signal (Dodge)
Immobilizer system – ECM EPROM malfunction (Hyundai)
CAN data bus, BCM -no signal (Jeep)
Engine control module (ECM)- EEPROM error (Kia)
CAN data bus, body control module (BCM) no signal (Plymouth)
Remote central locking module, entry signalvoltage low (Saturn)
Remote Keyless Entry Circuit Low Input Conditions (Chevrolet)
BAT Team Discussions for P1695
- P1698 No CCD Bus Messages Received, Instr Cluster Not Functioning '98 Chrysler Minivan
All - hoping someone has been through this because there's some moving pieces involved. 1998 Plymouth Voyager, base model with manual windows, no ABS, no tach. P1698 code and non-functioning instrument cluster, including no odometer readout. Cluster issue was intermittent but is now fulltime. Code P...
Have code p1695 van will run for a short time then dye
