P1690
Manufacturer Specific Definitions for P1690
Acura | Traction control system - circuit failure |
Alfa Romeo | Fuel shut-off control - malfunction |
Audi | Malfunction indicator lamp (MIL) - circuit malfunction |
Bmw | Charging system – battery discharged |
Buick | Engine Control Module Loop Overrun |
Cadillac | Engine Control Module Loop Overrun |
Chevrolet | Engine Control Module Loop Overrun |
Chrysler | Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor |
Citroen | Wastegate Solenoid Circuit Malfunction |
Daewoo | Water Heater Relay |
Dodge | Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor |
Ford | Wastegate Solenoid Circuit Malfunction |
Genesis | Immobilizer-Smartra No Response |
Gm | Engine Control Module Loop Overrun |
Honda | Traction Control System Circuit Failure |
Hyundai | Smartra No Response |
Jeep | Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor |
Kia | Immobilizer control module – malfunction |
Lexus | OCV for VVTL Circuit Malfunction |
Opel | Malfunction indicator lamp (MIL) - circuit malfunction |
Peugeot | Wastegate Solenoid Circuit Malfunction |
Pontiac | Rocker arm oil control actuator -circuit malfunction |
Ram | Crankshaft position/injection pump camshaft position sensor -correlation |
Toyota | Oil control valve/variable valve timing - malfunction |
Volkswagen | Malfunction indicator lamp (MIL) - circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1690 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
