P1687
Manufacturer Specific Definitions for P1687
Acura | AT to ECM - signal B - input high |
Buick | Driver 5 Line 7 |
Cadillac | Driver 5 Line 7 |
Chevrolet | Fuel injector control module (FICM) -stuck on |
Chrysler | CAN data bus, instrumentation -no signal |
Citroen | Metering Oil Pump Stepping Motor Circuit Malfunction |
Dodge | CAN data bus, instrumentation -no signal |
Gmc | Fuel injector control module (FICM) -stuck on |
Gm | Driver 5 Line 7 |
Honda | AT to ECM- signal 8- voltage high |
Isuzu | AT to ECM - signal B - voltage high |
Jeep | CAN data bus, instrumentation -no signal |
Kenworth | P1687 - Starter motor low side driver short circuit high |
Mazda | Rotor lubrication oil pump – high oil flow – circuit malfunction |
Peterbilt | P1687 - Starter motor low side driver short circuit high |
Peugeot | Metering Oil Pump Stepping Motor Circuit Malfunction |
Plymouth | CAN data bus, instrumentation no signal |
Ram | CAN data bus, instrumentation -no signal |
We have not gotten around to publishing a technical guide specifically for P1687 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
