P1686
Manufacturer Specific Definitions for P1686
Acura | AT to ECM - signal B - input low |
Bmw | ECM self-test- torque monitoring |
Buick | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
Cadillac | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
Chevrolet | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
Chrysler | CAN data bus, imobilizer control module no signal |
Citroen | Metering Oil Pump Stepping Motor Circuit Malfunction |
Dodge | CAN data bus, immobilizer control module no signal |
Gm | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
Honda | Engine torque signal – circuit high input |
Isuzu | AT to ECM - signal B - voltage low |
Jeep | CAN data bus, immobilizer control module no signal |
Kenworth | P1686 - Starter motor low side driver open circuit |
Mazda | Rotor lubrication oil pump – low oil flow – circuit malfunction |
Peterbilt | P1686 - Starter motor low side driver open circuit |
Peugeot | Metering Oil Pump Stepping Motor Circuit Malfunction |
Plymouth | CAN data bus, immobilizer control module no signal |
Pontiac | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
Ram | CAN data bus, immobilizer control module no signal |
Saturn | Transmission Control Module Power Up Temperature Sensor Circuit High Voltage |
