P1680
Reading P1680 on your car
P1680 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1680
AudiLimp-home mode - active
BmwVehicle speed sensor (VSS) signal
BuickEngine control module (ECM) -programmingl memory
CadillacEngine control module (ECM) malfunction
ChevroletEngine control module (ECM) -malfunction
ChryslerClutch pedal position (CPP) switch -circuit malfunction
CitroenMetering Oil Pump Malfunction
DodgeCommunication Bus
GmcEngine control module (ECM) -malfunction
GmControl Module Not Programmed
HummerEngine control module (ECM) -malfunction
IsuzuEngine control module (ECM) – malfunction
JeepClutch pedal position (CPP) switch -circuit malfunction
OldsmobileEngine control module (ECM)
PeugeotMetering Oil Pump Malfunction
PontiacEngine control module  (EeM) – malfunction
RamClutch pedal position (CPP) switch -circuit malfunction
SaturnEngine control module (ECM) -malfunction
VolvoCAN data bus, immobilizer control module – no signal
VolkswagenLimp-home mode - active
We have not gotten around to publishing a technical guide specifically for P1680 yet.
