P1660
Reading P1660 on your car
P1660 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1660
AcuraAT to ECM - signal failure
AudiEngine coolant blower motor, speed 1 - short to ground
BuickEngine control module (ECM) quad driver/output driver
CadillacEngine coolant blower motor relay(s) -circuit malfunction
ChevroletEngine control module, output driver 3 -supply voltage high
CitroenOutput Circuit Check Signal High
DaewooMalfunction indicator lamp (MIL) -voltage high
FordOutput Circuit Check Signal High
GmEngine control module (ECM), quad driver/output driver – circuit malfunction
HondaAT to ECM – data line failure – V6
HyundaiCruise Control Switch - Malfunction
IsuzuAT to ECM - data line failure
LamborghiniPower stage group 'B'
OldsmobileEngine coolant blower motor relay(s) -circuit malfunction
OpelFuel shut - off solenoid - circuit malfunction
PeugeotOutput Circuit Check Signal High
PontiacEngine control module (EeM), quad driver/output driver – circuit malfunction
SaturnTransmission control module (TCM), ground detection -malfunction
VolvoCruise control master switch – signal high
VolkswagenEngine coolant blower motor, speed 1 - short to ground
We have not gotten around to publishing a technical guide specifically for P1660 yet.
