P1652
Manufacturer Specific Definitions for P1652
Audi | Transmission control module (TCM) - system malfunction |
Buick | Engine coolant blower motor relay 2 -circuit malfunction |
Cadillac | Suspension control module -engine control module (ECM), accelerationlbraking signal malfunction |
Chevrolet | Engine coolant blower motor relay 2 -circuit malfunction |
Chrysler | CAN data bus -short circuit to ground |
Citroen | IAC Monitor Disabled by PSP Switch Failed On |
Daewoo | Ignition Sw Fault |
Dodge | CAN data bus -short circuit to ground |
Gm | Cooling Fan 2 Relay Control Circuit Conditions |
Hyundai | Ignition Switch Malfunction |
Jeep | Data bus, engine control module (ECM)/transmission control module (TCM) -no communication |
Kenworth | P1652 - Red stop lamp low side driver short circuit high |
Mazda | Power steering pressure (PSP) switch – circuit malfunction |
Oldsmobile | Engine coolant blower motor relay 2 -circuit malfunction |
Peterbilt | P1652 - Red stop lamp low side driver short circuit high |
Peugeot | IAC Monitor Disabled by PSP Switch Failed On |
Pontiac | Engine coolant blower motor relay 2 & 3 circuit malfunction |
Ram | CAN data bus -short circuit to ground |
Saab | Engine control module (ECM) – ROM error |
Toyota | Turbocharger (TC) 2 air control solenoid - circuit malfunction |
Volvo | Engine control module (ECM), primary fuel cut-off – implausible signals between sensors |
Volkswagen | Transmission control module (TCM) - system malfunction |
We have not gotten around to publishing a technical guide specifically for P1652 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
