P1651
Reading P1651 on your car
P1651 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1651
| Make | Fault Location |
| Buick | Engine coolant blower motor relay 1 -circuit malfunction |
| Cadillac | Fan 1 Relay Control Circuit |
| Chevrolet | Engine coolant blower motor relay 1 -circuit malfunction |
| Citroen | PSP Switch Input Malfunction |
| Daewoo | Eng Fix Indc Lamp Ct(Open/Gnd) |
| Daihatsu | TPS input circuit abnormal(A/D) |
| Ford | Power Steering Pressure Switch Input Malfunction |
| Gm | Cooling Fan 1 Control Relay Circuit Conditions |
| Land Rover | Power steering pressure (PSP) switch – circuit malfunction |
| Lincoln | Power steering pressure (PSP) switch -input |
| Mazda | Power steering pressure (PSP) switch – input malfunction |
| Mercury | Power steering pressure (PSP) switch -input |
| Oldsmobile | Engine coolant blower motor relay 1 -circuit malfunction |
| Opel | Fuel injection pump control module,CAN data bus - malfunction |
| Peugeot | PSP Switch Input Malfunction |
| Pontiac | Engine coolant blower motor relay 1 -circuitmalfunction |
| Saab | Engine control module (ECM) – RAM error |
| Saturn | Engine control module (ECM), quad driverl output driver -circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1651 yet.
