P1650
Manufacturer Specific Definitions for P1650
Acura | Engine Control Module Quad Driver / Output Driver |
Audi | CAN data bus, instrumentation - no signal |
Bmw | Battery temperature sensor circuit – electrical fault |
Buick | Engine control module, quad driver/output driver |
Cadillac | Engine control module, output driver 2 -supply voltage high |
Chevrolet | Engine control module, output driver 2 -supply voltage high |
Citroen | PSP Switch Out of Self Test Range |
Daewoo | Engine control module (ECM), SPI communication with SIDM chip – malfunction |
Daihatsu | G sensor input circuit abnormal(A/D) |
Ford | Power Steering Pressure Switch Out of Self-Test Range |
Gm | Output Driver Module 2 Input High Input Conditions |
Honda | Engine control module quad driver/output driver |
Hyundai | Malfunction Indicator Lamp (MIL) Control Circuit |
Isuzu | Engine control module quad driver/output driver |
Kenworth | P1650 - Red stop lamp low side driver open circuit |
Land Rover | Power steering pressure (PSP) switch |
Lincoln | Power steering pressure (PSP) switch -malfunction |
Mahindra | Mil Over Temperature Error |
Mazda | Power steering pressure (PSP) switch – out of self-test range |
Mercury | Power steering pressure (PSP) switch -malfunction |
Oldsmobile | Engine control module (ECM) quad driver! output driver |
Opel | Malfunction indicator lamp (MIL) - circuit malfunction |
Peterbilt | P1650 - Red stop lamp low side driver open circuit |
Peugeot | PSP Switch Out of Self Test Range |
Pontiac | Engine control module (EeM), quad driver/output driver – circuit malfunction |
Renault | Control box connection heaters |
Saturn | Engine control module (ECM), quad driverl output driver -circuit malfunction |
Volvo | Camshaft position (CMP) actuator, inlet camshaft – signal high |
Volkswagen | CAN data bus, instrumentation - no signal |
We have not gotten around to publishing a technical guide specifically for P1650 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
