P1639
Manufacturer Specific Definitions for P1639
Audi | Accelerator pedal position (APP) sensor 1/2 - range/performance problem |
Bmw | Radiator ventilation, upper- electrical fault |
Buick | Sensor supply voltage -circuit Bmalfunction |
Cadillac | Sensor supply voltage -circuit B malfunction |
Chevrolet | Engine control module (ECM). sensor supply voltage -circuit malfunction |
Chrysler | TCM Internal CAN 2 RAM Performance |
Citroen | Vehicle ID Block Corrupted or Not Programmed |
Daewoo | Ecu (Micom) Crct Fault |
Dodge | TCM Internal CAN 2 RAM Performance |
Ford | Vehicle ID Block Corrupted or Not Programmed |
Gmc | Engine control module (ECM), sensor supply voltage -circuit malfunction |
Gm | TCM Analog To Digital Converter Conditions |
Honda | Motor control module (MCM) -signal circuit malfunction |
Hyundai | ECM (Monitoring ADC) - Malfunction |
Isuzu | Sensor supply voltage - circuit B malfunction |
Jeep | TCM Internal CAN 2 RAM Performance |
Lincoln | Engine control module (ECM) -invalid or missing data |
Mazda | Engine control module (ECM) -keep alive test error |
Mercury | Engine control module (ECM) -invalid or missing data |
Oldsmobile | Sensor supply voltage -circuit B malfunction |
Peugeot | Vehicle ID Block Corrupted or Not Programmed |
Pontiac | Engine control module (ECM), sensor supplyvoltage -circuit malfunction |
Saturn | Engine control module (ECM) -malfunction |
Volkswagen | Accelerator pedal position (APP) sensor 1/2 - range/performance problem |
