P1635
BAT Team
Manufacturer Specific Definitions for P1635
AudiCAN data bus, AC - no signal
BmwKnock sensor (KS), 3 – control circuit internal failure
BuickSensor supply voltage -circuit A malfunction
CadillacSensor supply voltage -circuit A malfunction
ChevroletEngine control module (ECM). sensor supply voltage -circuit malfunction
CitroenTire / Axle Ratio Out of Acceptable Range
DaewooEngine control module (ECM), sensor reference voltage low
DodgePCM Memory Performance or Write
FordTire / Axle Ratio Out of Acceptable Range
GmcEngine control module (ECM), sensor supply voltage -circuit malfunction
Gm5-Volt Reference Circuit Low Conditions
HondaBattery condition monitor module – malfunction
HyundaiWater Heater Relay-Malfunction
IsuzuSensor supply voltage - circuit A malfunction
LincolnTire/axle ratio out of range
MazdaEngine control module (ECM)- processor fault
MercuryTire/axle ratio out of range
OldsmobileSensor supply voltage -circuit A malfunction
OpelEngine control module (ECM) - defective
PeugeotTire / Axle Ratio Out of Acceptable Range
PontiacEngine control module (ECM). sensor supplyvoltage -circuit malfunction
SaturnSensor supply voltage, circuit malfunction
VolvoEngine control module (ECM), internal temperature sensor – signal low
VolkswagenCAN data bus, AC - no signal
We have not gotten around to publishing a technical guide specifically for P1635 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
