P1634
Manufacturer Specific Definitions for P1634
Audi | Accelerator pedal position (APP) sensor 2 - high input |
Bmw | ECM self-test – bank 1 knock control malfunction |
Buick | Engine control module (ECM), ignition supply voltage |
Cadillac | Engine control module (ECM) -ignition supply voltage -voltage low |
Chevrolet | Engine control module (ECM), ignition supply voltage |
Citroen | Data Output Link Circuit Failure |
Daewoo | Cruise Lamp Fault |
Daihatsu | EFI(main)CPU abnormal |
Ford | Data Output Link Circuit Failure |
Gmc | Engine control module (ECM) -ignition supply voltage -voltage low |
Gm | Ignition 1 Power Circuit Low Input Conditions |
Honda | Motor power inverter module – signal circuit malfunction |
Hyundai | Auxiliary Heater Relay Short or Open |
Kia | Generator terminal B – open circuit |
Mazda | Generator terminal B – open circuit |
Oldsmobile | Engine control module (ECM) -ignition supply voltage -voltage low |
Peugeot | Data Output Link Circuit Failure |
Pontiac | Engine control module (ECM) -ignition supply voltage -voltage low |
Saab | Engine control module (ECM) – ignition supply voltage – voltage low |
Volkswagen | Accelerator pedal position (APP) high input |
