P1625
Manufacturer Specific Definitions for P1625
Acura | Engine Control Module Unexpected Reset |
Audi | CAN data bus, TCM - incorrect signal |
Bmw | Manifold differential pressure (MOP) sensor, bank 1 – implausible signal |
Buick | PCM Flash Checksum TCM Conditions |
Cadillac | PCM Flash Checksum TCM Conditions |
Chevrolet | PCM Flash Checksum TCM Conditions |
Citroen | B+ Supply To VCRM Fan Circuit Malfunction |
Daewoo | A/C Fan Mal |
Ford | Voltage to Vehicle Load Control Module Fan Circuit Not detected |
Gm | PCM Flash Checksum (TCM) Conditions |
Honda | Engine control module (ECM) - unexpected reset |
Hyundai | Cooling Fan Relay(High) Circuit |
Isuzu | Engine control module (ECM) – unexpected reset |
Kia | Engine coolant blower motor relay high speed – circuit malfunction |
Lincoln | Variable load control module, power supply to engine coolant blower motor -circuit malfunction |
Opel | Engine control module (ECM) - malfunction |
Peugeot | B+ Supply To VCRM Fan Circuit Malfunction |
Saab | CAN data bus, TCS/ABS |
Saturn | Engine control module (ECM) -memory malfunction |
Suzuki | Immobilizer control module – antenna malfunction |
Volvo | Malfunction indicator lamp (MIL) -signal low |
Volkswagen | CAN data bus, TCM - incorrect signal |
