P1621
Reading P1621 on your car
P1621 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1621
AudiInstrument panel, ECT signal - short to ground
BuickEngine control module (ECM) -programmingl memory
CadillacEngine control module (ECM) -memory performance
ChevroletEngine control module (ECM) -malfunction
CitroenControl Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
DaewooFuel Cut Valve Mal
DodgeSpeed Control Switch Always High
GmcEngine control module (ECM) -memory performance
GmControl Module Long Term Memory Performance Conditions
HummerEngine control module (ECM) memory performance
HyundaiFuel Cut Valve-Malfunction.
IsuzuEngine control module (ECM) – internal memory performance
JaguarEngine control module (ECM)
Land RoverImmobilizer control module
MazdaEngine control module (ECM) – incorrect immobilizer code after cranking
OldsmobileEngine control module (ECM) -memoryperformance
OpelEngine control module (ECM) - defective
PeugeotControl Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
PontiacEngine control module (EeM) – memory performance
SaabEngine control module (ECM) – memory performance
SaturnEngine control module (ECM) -memory performance
SuzukiImmobilizer control module/engine control module (ECM) – communication malfunction
VolvoInstrumentation control module, real time clock – communication malfunction
VolkswagenInstrument panel, ECT signal - short to ground
We have not gotten around to publishing a technical guide specifically for P1621 yet.
