P1611
Manufacturer Specific Definitions for P1611
Audi | Malfunction indicator lamp (MIL) - short to ground |
Buick | Loss Of Continuous Variable Real Time Damping Serial Data Conditions |
Cadillac | Suspension control module |
Chevrolet | Loss Of Continuous Variable Real Time Damping Serial Data Conditions |
Citroen | SBDS Interactive Codes |
Daewoo | Engine control (EC) relay – voltage low |
Dodge | Engine control module (ECM) -5 volt output erratic |
Ford | Engine control module (ECM) |
Freightliner | Engine control module (ECM) -5 volt output erratic |
Gm | Loss of CVRTD Serial Data Conditions |
Hyundai | Ventilation Solenoid Valve Stuck On |
Infiniti | Immobilizer control module/engine control module (ECM) – coding |
Kia | MIL request signal – circuit/voltage low |
Lamborghini | MIL request circuit low voltage |
Mahindra | Main Relay Early Opening |
Nissan | Immobilizer control module/engine control module (ECM) – coding |
Opel | Immobilizer control module - incorrect security code entered |
Peugeot | SBDS Interactive Codes |
Porsche | MIL Activated Externally |
Volvo | CAN data bus, ETS – no update signals |
Volkswagen | Malfunction indicator lamp (MIL) - short to ground |
We have not gotten around to publishing a technical guide specifically for P1611 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
Witam. Obd wykryli mi błąd P1611. Proszę o pomoc co się dzieje i jak naprawić usterkę. Dziękuję
