P1610 – SBDS Interactive Codes
Last Updated 2018-09-27
P1610 | P1610 – SBDS Interactive Codes (Buy Part On Amazon) |
Manufacturer Specific Definitions for P1610
Audi | Engine control module (ECM) - defective |
Buick | CAN data bus -body control module (BCM) |
Cadillac | CAN data bus -body control module (BCM) |
Chevrolet | CAN data bus -body control module (SCM) |
Chrysler | Immobilizer control module -circuit malfunction |
Citroen | SBDS Interactive Codes |
Daewoo | Engine control (EC) relay – voltage high |
Dodge | Immobilizer control module -circuit malfunction |
Ford | Engine control module (ECM) |
Freightliner | Engine control relay -defective |
Gm | Loss of Platform Zone Module (PZM) Serial Data Conditions |
Hyundai | Non-Immobilizer-EMS Connected to an Immobilizer |
Infiniti | Ignition key/engine control module (ECM) – malfunction |
Mitsubishi | Immobilizer control module – circuit malfunction |
Nissan | Ignition key/engine control module (ECM) – malfunction |
Oldsmobile | CAN data bus -body control module (BCM) |
Opel | lmmobilizer control module - program error |
Peugeot | SBDS Interactive Codes |
Pontiac | CAN data bus. engine control module (ECM) to body control module (BCM) -communication failure |
Porsche | MIL Activated Externally |
Volvo | Electronic throttle system (ETS)- throttle valve command/actual throttle valve position, correlation |
Volkswagen | Engine control module (ECM) - defective |
What Does Code P1610 Mean?
OBD II fault code P1610 is a manufacturer specific code that is defined by car makers Ford, Citroen, and Peugeot as “SBDS (Service Bay Diagnostic System) Interactive Codes”. Note that on Ford applications, this code is defined as P1610 – “Interactive Reprogramming Code – replace (anti-theft) module (used with P1615/17/19/20)”, and is set when the PCM (Powertrain Control Module) on the affected application detects an unspecified malfunction in, or, failure of the anti-theft system. Note that this code is very common on many Ford applications, and only marginally less common on Peugeot and Citroen models,
Note that “used with P1615/17/19/20” refers to Ford-specific OBD II fault codes P1615, P1617, P1619, and P1620, one or more (or sometimes all) of which usually accompanies P1610 on Ford applications. However, these codes also have no definition beyond “SBDS (Service Bay Diagnostic System) Interactive Codes”, which means that there is little, to no information about these codes available to the independent repair trade.
Be aware that in the case of Citroen and Peugeot applications, there is no information beyond the definition- P1610 –“SBDS (Service Bay Diagnostic System) interactive codes” available to the independent repair trade. Therefore, when code P1610 appears on Peugeot/Citroen applications, the affected application is best referred to the authorized dealer.
Systems like anti-theft, infotainment, and keyless entry are controlled by proprietary software, algorithms, and specialized communication protocols that require an interaction between components, such as smart keys, transponders, and specialized code readers to work. Thus, being proprietary, the PID’s (code setting parameters/fault identifiers) for proprietary control systems are neither published, nor shared with manufacturers of diagnostic equipment that is available to the independent repair trade.
In practical terms, “Service Bay Diagnostic System” is OBD-speak, and it means that the problem exists in a system that is considered captive technology, in the sense that only dealerships (usually, but not always) have access to the diagnostic software, equipment, and technical information to access, diagnose, and repair the issue.
Why does code P1610 affect Ford, Citroen, and Peugeot applications more than others?
While this code refers to an anti-theft module failure in the case of Ford applications, there is no information available on the typical causes and/or conditions that could have produced the module failure. In the case of Peugeot and Citroen applications, there is no information available at all.
Where is the P1610 sensor located?
The image above shows a simplified schematic of the anti-theft system on a Ford Taurus application. Note that while this layout is representative of all Ford applications, the actual locations of the various components in a Ford anti-theft system vary greatly between models. Therefore, it is important to refer to the manual for the affected application to locate and identify individual components correctly.
What are the common causes of code P1610?
It should be noted that code P1610 may or may not be related to one or more other SBDS codes, these being-
- P1611 – SBDS Interactive Codes
- P1612 – SBDS Interactive Codes
- P1613 – SBDS Interactive Codes
- P1614 – SBDS Interactive Codes
- P1615 – SBDS Interactive Codes
- P1616 – SBDS Interactive Codes
- P1617 – SBDS Interactive Codes
- P1618 – SBDS Interactive Codes
- P1619 – SBDS Interactive Codes
- P1620 – SBDS Interactive Codes
Nonetheless, experience has taught that while code P1610 refers to a failure of one or more proprietary systems in the anti-theft system on Ford applications, there are exceptions to this rule, including-
- Damaged, burnt, shorted, disconnected, and or corroded wiring and/or connectors almost anywhere in the anti-theft, and/or keyless entry systems
- Attempting to start the vehicle with the wrong key more than a specified number of times
- Corrupted or failed software in a smart key
- Failure of an anti-theft system related transponder, and/or code reader
- Illegal, unauthorized, or ill-considered modifications to the vehicle’s security system(s), such as attempting to install an aftermarket alarm or other theft-deterrent device
BUENAS TARDES, MI PROBLEMA ES EL CODIGO 500 Y EL 1614.
EN BADAJOZ NADIE SABE QUE LE PASA AL ASTRA 1700 CDTI.
SI TIENE SOLUCION ,ME LA PODIAN INDICAR?
I’d like to know what the ,EEPROM is and the SBDS are cuz that’s the definition from the numbers on my code reader threw out. P1610 & P1603 ON MY MITSUBISHI ECLIPSE GT V6 AUTO 2001
